GeometryPropertyExtractor can't get properties?
  • Nov 2, 2022 12:19 AM UTC
  • 151 views
I'm trying to isolate circle polys with a -360 Sweep Angle below but can't get any traits from the GeometryPropertyExtractor? Anyone know the settings and/or query to use here?
IFMEPolygon
  Linear Boundary No
  Convex Yes
  Orientation Right Hand Rule
  Boundary: IFMEPath (1 Segment)
    Closed Closed In 2D
    Segment 0: IFMEArc Arc By 3 Points
      Closed Closed In 2D
      CW/CCW Clockwise
      (Circle) Radius 49.999964742921485
      Start Point 561532.7739287984, 5274944.139919876
      Mid Point 561532.7739375194, 5274844.139990389
      End Point 561532.7739287984, 5274944.139919876
      Rotation (Degrees CCW) 0
      Start Angle (Degrees CCW) 90.00000499684722
      Sweep Angle (Degrees CCW) -360
f.kemminje
Forum|alt.badge.img+11
  • Nov 2, 2022 4:39 AM UTC
itsmatt
Forum|alt.badge.img+48
  • Nov 2, 2022 3:03 PM UTC
Arcs have a specific tool - ArcProperyExtractor. This should the info you want
