Geometry simplify
  • May 14, 2020 12:27 PM UTC
  • 5 replies
  • 1854 views
Hi FME community,
I need help to do one little thing:
I have a request to simplify the geometries I processed with a tolerence of 0.5 meter
The geometries come from two tables and at the end they are saved as Geometrycollection (with aggregator).
Thanks for you help...
  • May 14, 2020 12:37 PM UTC
Have you already looked at the Generalizer? There's also a derived version of it on the FME Hub called the GeographicGeneralizer that may be helpful in this particular case.
If the data has a topology that needs to be preserved, also look at the SherbendGeneralizer.
  • May 14, 2020 12:59 PM UTC
@david_r thanks for your answer.
I read some posts with the "Generalizer" but I don't now how to implement it correctly.
The feature SRID is 31370(Lamb72) so I guess that it's meter unit... so in the Generalizer I put 0.5 in the parameters:
Is it the right way to do ?
In the inspector , there is a line with 44 coordinates and after the Generalizer it's 5. Could it be possible ?
  • May 14, 2020 1:23 PM UTC
The Generalizer is surprisingly complex and the results can vary wildly depending on the configuration and the input data, so I would strongly recommend to read through the documentation first, if you haven't already: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/generalizer.htm
Forum|alt.badge.img+63
Depending on what your line looks like it's perfectly possible to go from 44 to 5 coordinates (if it's rather straight and you set the tolerance high enough it'll go down to just 2). You need to take a look at the results and consider whether they look good enough.
Different algorithms have different results and different settings. Sometimes you need to combine them (run 2 Generalizers, one after the other).
erik_jan
Forum|alt.badge.img+26
  • May 14, 2020 2:30 PM UTC
The CoordinateRounder could be used to round the coordinates to a number of decimals.
But that would round in your case either to 0 or 1 decimal, which is a meter of decimeter if your data is in meters.
