Geometry from lat lon degrees and decimal minutes
I receive a text file with latitude and longitude coordinates.
The coordinates are typed in manually by the user using a reasonably similar syntax, although number of decimal places at the minute vary from none to four.
Examples of variation:
latitude: +70°38,91 +63°47 +69°56,426 +69°08,8447
longitude:-51°04 -50°40,5 -51°19,01 -50°52,600 -50°52,9597
How could I use regex to convert the values to decimal degrees?
Forum|alt.badge.img+39
  • May 26, 2016
I don't think you necessarily need to use regex. If you use a stringreplacer to replace the degree with a comma, then an attributesplitter to split the attribute into degrees, minutes and seconds, you can then feed this into the decimaldegreescalculator.
You will need to handle those cases where there are no seconds listed
erik_jan
Forum|alt.badge.img+18
  • May 26, 2016
Have you tried the AttributeReprojector? It might have a way to reproject the coordinates to the wanted syntax.
  • May 27, 2016
Hi @karl_zinglersen, how about this?
  1. Split each value at "°" using the AttributeSplitter. The resulting _list{0} contains the value of degrees; _list{1} contains the value of decimal minutes.
  2. Replace comma (,) in the decimal minutes (_list{1}) with the decimal point (.) using the StringReplacer.
  3. Calculate the value in decimal degrees from the list elements using the ExpressionEvaluator with this math expression
@Value(_list{0}) + (@Value(_list{0}) < 0 ? -@Value(_list{1}) : @Value(_list{1})) / 60.0
[Addition] If you are using FME 2014 or earlier, you should add the decimal point to the divisor (60) in the expression. Otherwise, int / int returns an integer (decimal places in the resulting value will be truncated).
  • May 27, 2016
While I agree that you can easily do this without resorting to using regex, here's a regex nonetheless ;-)
([\+\-]?\d+)\D*([\d,]+)
It will split up the string in two parts, one before and after a non-digit (e.g. the degrees sign or a space).
 Usage:
Look for the results in the list _matches{}.part, here's an example for the input string "+69°56,426":
`_matches{0}.part' has value `+69'
`_matches{1}.part' has value `56,426'
It is then easy to send it off to the DecimalDegreesCalculator, if needed.
David
