Geometry fails OGC - GeometryValidator fails to repair
  • May 19, 2020 8:01 PM UTC
  • 970 views
mathiku
Forum|alt.badge.img+8
I am receiving geometries from MapInfo .TAB-files.
They are then to be passed on to a server in a XML-file. I parse the geometries using GeometryExtractor -> GML 3.1.1.
No problem - the GeometryValidator -> DonutBuilder -> GeometryExtractor seems rock solid.
Today I encountered this geometry which I can't seem to pass on. It fails OGC and GeometryValidator fails to repair it.
For now my workaround is to add a small buffer, but does anybody have a better method?
Attached is the geometry as TAB_file.
Best answer by itsmatt
I find that the GeometryValidator never repairs when performing the OGC test. Perhaps try the validator without the OGC test - as @takashi for the case you have here a SpikeRemover should work, or alternatively setting the tolerance a little higher in the self-intersecting test or duplicate/consecutive points test.
  • May 19, 2020 8:24 PM UTC
Hi @mathiku, the SpikeRemover might help you.
itsmatt
Forum|alt.badge.img+48
  • May 20, 2020 7:27 AM UTC
mathiku
  • May 20, 2020 8:07 AM UTC
Thanks. Removing the OGC tests did the trick. Very simple :)
mathiku
  • May 20, 2020 8:08 AM UTC
Thanks for the suggestion. I tried some different settings, but didn't get the desired result, and changing settings in GeometryValidator was really simple.
