Geometry Challenge - Perpendicular line (Same X Coordinate)
  • Dec 15, 2023 11:03 AM UTC
  • 135 views
galigis
Forum|alt.badge.img+22
Hi All,
I'm working on a workflow to identify if line is perpendicular and shows the same X at both vertex . Below a screenshot that shows a line pointing to the north but the X (top vertex) is different to X (bottom vertex). imageThe aim of the is fail the lines which are not perpendicular and show different Xs,
I was thinking about TopoBuilder but can't get it to work,
Any ideas? Thanks :)
nielsgerrits
Forum|alt.badge.img+67
Not sure if this is what you are looking for, but I use the LabelPointReplacer to get the ParallelRotation direction of a line.
  • GeometryExtractor (FME Binary) to backup the geometry to an attribute.
  • LabelPointReplacer with label 1 and labelheight 1 to replace the line with a label.
  • AttributeExposer to expose ParallelRotation.
  • GeometryReplacer to restore the original geometry from the attribute.
Once you have the directions of the lines in attributes, you can calculate if it is 90 degrees different from the one you are testing.
Forum|alt.badge.img+63
In addition to @nielsgerrits​ very novel solution, I can think of two more approaches:
  • There's a HorizontalAngleCalculator custom transformer available on the FME Hub, which calculates the angles of line features, a line with both x coordinates the same will have an angle of 90 or 270 degrees
  • The CoordinateExtractor can extract coordinate values into a list (_indices{}), assuming you have a 2-point line you can then test to see if _indices{0}.x = _indices{1}.x
galigis
  • Dec 15, 2023 1:51 PM UTC
Thanks @nielsgerrits​  and @Hans van der Maarel​  both solutions worked perfectly :)
