GEODATABASE_SDE writer ignores table qualifier on 'Create if Needed' or 'Drop and Create'
  • Feb 3, 2026 10:25 PM UTC
  • 174 views
artw
Apologies if this has already been asked - seems like it should already have been reported.
FME Form 2025.0.1
FeatureWriter Version 0
Writing to Esri Geodatabase on MSSQL Server 2019
When using either Create if Needed, or Drop and Create table handling, the geodatabase_sde writer appears to ignore the table qualifier set on the feature type.
The table gets successfully created, visible in SSMS - but under the default user database schema eg: domain\john.smith.FeatureClass1
However the flow then fails because at some stage it does take into account the table qualifier and is looking for a table called sde.FeatureClass1
An error occurred while attempting to create the table 'sde.FeatureClass1'. The error number from ArcObjects is: '-2147220655'. The error message from ArcObjects is: {DBMS table not found [{dbname}.sde.FeatureClass1]}
The user has appropriate permissions on the sde schema
(Note: It is an Esri requirement that the users default database schema name matches the username, so the default can’t just be changed in SSMS)
Best answer by desiree_at_safe
Hi ​@artw
What version of ArcGIS Pro and the Geodatabase do you have installed?
As a quick check outside of FME: using the exact same .sde connection file, is the user able to manually create a Feature Class named sde.FeatureClass1 directly inside ArcGIS Pro?
It’s possible there’s a mismatch between how FME is instructing the table creation versus how the default schema is being handled; that ArcObjects error -2147220655 (DBMS table not found) is especially interesting.
Would you also be willing to share a full log file with Log Debug enabled first:
 Utilities > FME Options > Translation > Log Debug
desiree_at_safe
Forum|alt.badge.img+25
Hi ​@artw
artw
  • Feb 5, 2026 10:59 PM UTC
ArcGIS Pro 3.3.7
Geodatabase 10.9.1.2.9
But you’ve probably explained it there ​@desiree_at_safe
Using normal Esri processes, tables always need to be created as the dataowner (schema owner), doesn’t matter about permissions.
So while permissions can allow another user to delete a table, Esri rules means the recreation can only happen from the dataowner account.
FME obviously doesn’t allow us to get around this restriction - and is a bit of an annoyance if we try to use Drop and Create, from a user account, as opposed to the dataowner account.
