Geocoder w/ ArcGIS Server - Error 403: Access to this resource is not allowed
  • Aug 1, 2024 6:38 PM UTC
  • 844 views
drewpurzycki
Forum|alt.badge.img+14
I am attempting to add a Geocoder transformer to spatialize address data using a published geocoding service on ArcGIS Server. When running the address data to the transformer, it rejects every feature with “Code 403: Access to this resource is not allowed”. The REST URL and Portal credentials are all correct and I am able to get to the service in a browser, as well as access and use the Locator in ArcGIS Pro to geocode addresses. With that being said, I don’t know why access to the resource would be disabled in FME but nothing else. Any insight or suggestions would be appreciated, thank you!
Best answer by drewpurzycki
Hi, @drewpurzycki.
Thank you for posting and for your patience. Before delving further, could you share which version of FME Form/Desktop and ArcGIS Server your using? It’ll help us better assist your use case.
Thank you!
Hi Ali,
I’m using the ArcGIS Data Interoperability extension for Pro (2.9) and the ArcGIS Server is version 10.91.
Edit: I ended up needing to use an updated version of the Geocoder transformer, which let me use a Portal web connection to authenticate and connect to the locator REST service. Thanks!
ali-safe
Forum|alt.badge.img+24
  • Aug 2, 2024 4:30 PM UTC
Hi, @drewpurzycki.
Thank you for posting and for your patience. Before delving further, could you share which version of FME Form/Desktop and ArcGIS Server you’re using? It’ll help us better assist your use case.
Thank you!
drewpurzycki
  • Aug 2, 2024 4:35 PM UTC
Hi, @drewpurzycki.
Thank you!
Hi Ali,
