generating an AutoCAD table from a shape file
  • May 4, 2020 2:15 PM UTC
  • 0 replies
  • 40 views
I am trying to generate a table with N columns and R rows as a layout page in a DWG file. I have this table defined as a template and the data is from different sources like shape files. I am creating a Multi-text for each field and using a VertexCreator with a fixed x,y position in the paper space to place them at each column. Everything works fine except that the rows are filled in the upward direction rather in the downward direction.
Is there a way to auto calculate the position of next row ( x,y ) for multi-text or any other ways to auto fill the table ? any insights to set the rows automatically would be highly appreciated.
