GDB to SHP field length >254
  • Jun 30, 2022 5:08 AM UTC
  • 5 replies
  • 143 views
viviancfhung
We want to convert a GDB to SHP file with field type string and length>254. How can we keep the data with maximum size 254, but not ignore the data
Thanks
birgit
Forum|alt.badge.img+25
  • Jun 30, 2022 7:03 AM UTC
I don't think this is possible it is literally a limitation of the .shp format. Your only option is to use another format. I guess you could split up the attribute that contains more than 254 characters into multiple attributes.
See the same question on another site
viviancfhung
  • Jun 30, 2022 7:43 AM UTC
understand. Is any tramsformer can I used to change the max field length of schema if the data is not long, but the schema field length is 65536
Forum|alt.badge.img+63
There's no need to use a transformer for that, you can specify the field length in the Shape writer (with that 254 char maximum of course)
viviancfhung
  • Jun 30, 2022 10:03 AM UTC
Thanks, But we are using Dynamic schema
@viviancfhung​ The shape file .dbf file has a limit on the text length of 254 as mentioned by @Hans van der Maarel​
