GDB Alias with dynamic schema?
  • Oct 6, 2021 7:55 AM UTC
  • 8 replies
  • 233 views
francescodb
Hi, I have a workspace that write to SDE using a dynamic schema. The schema is build from an excel sheet where I have the name of the field, the type and the alias. I manage to write to SDE with all the correct parameter:
attribute{0}name
attribute{0}.fme_data_type
attribute{0}.native_data_type
The problem is that I cannot find a way to write alias. Anyone know if this is possible within a dynamic schema?
thank you!
nielsgerrits
Forum|alt.badge.img+67
From the article Working with Geodatabase Field Aliases: Altering Alias Values
FME is able to create attribute aliases for features read into the workspace that do not have aliases. This is possible if there is an additional attribute with the same name as the original attribute and is suffixed with "_alias". The value of that attribute will be used as the alias on table creation.
For example, there is an attribute named CentreAddress and there is another attribute named CentreAddress_alias with a value of Address. The value of CentreAddresss_alias will be used as the alias of CentreAddress (alias: Address). This only needs to occur on the first feature.
Not tried myself but I think this should work.
francescodb
Yes that's correct and I have used it that way other times but now I am using a dynamic shema so I want to include the alias in the schema definition
  • Oct 6, 2021 8:44 AM UTC
The easiest way to see what FME expects, is sometimes to "reverse engineer" the schema definition from an identical reader. You can e.g. do this using a FeatureReader on an existing GDB with aliases, and inspect the resulting schema features, which should show you what the corresponding writer expects.
francescodb
Hi David, I tried that and the only three attributes that are included in the shema definition are name, native_data_type and fme_data_type. The alias is exposed in the feature.
Featureschema
francescodb
Hi again, I solved this by sending a feature with all the alias to the writer. I now have another issue when writing to sde. When I set native_data_type to "integer" FME writes the attribute as text and not as defiuned in the schema. Anyone know how to solve this?
danminneyatsaf
Forum|alt.badge.img+13
Hi @francescodb​, it sounds like this is something that shouldn't be happening if you've defined it as an integer in the schema. Would you be able to share a screenshot of your settings and the resulting attribute?
francescodb
Hi @danminneyatsaf​ after a lot of trying I actually managed to get it right! I changed the fme_data_type from fme_int64 to fme_int32 and stopped using the native_data_type and the schema has been created with the right data type!
adnanyazdani
Forum|alt.badge.img+3
@francescodb​
Is it possible to share the workspace , If possible
Thanks
