FTPCaller - Protocols and algorithms for SFTP - follow up
  • Aug 12, 2025 9:36 PM UTC
  • 139 views
jonathan.spark
Forum|alt.badge.img+4
Hi there,
This is a follow up question to one I asked last year around the FTPCaller transformer:
Our security team granted a 12 month exemption to our FME workspace and have asked for an update on the issue.
Is there any change in the ability of the FTPCaller transformer to be able to view or configuring the cryptographic algorithms used?
Thank you,
Jonathan
j.botterill
Forum|alt.badge.img+69
  • Aug 13, 2025 1:53 AM UTC
To my knowledge and reading over the go to article, FME can authenticate to sFTP using two options
putty/pageant generating of private/public key exchange
open SSH
https://support.safe.com/hc/en-us/articles/25407554321805-Using-a-Private-SSH-key-with-FTPCaller-to-Authenticate-an-SFTP-Connection-for-FME-Form-and-FME-Flow-on-Windows-Systems
jonathan.spark
Thanks for the reply, ​@j.botterill.
Authentication is not an issue here, as we have authentication working fine using OpenSSH for Windows ssh-agent.
The question is instead around the cryptographic algorithms on the SFTP connection itself, whether they can be configured explicitly for the FTPCaller transformer, or at least viewed within FME.
j.botterill
  • Aug 15, 2025 12:05 AM UTC
If you can’t find anything on the parameters nor the help, then its a support question for Safe https://support.safe.com/hc/en-us/requests/new
