Formatting coordinate string and adding comma's
  • Dec 29, 2017 1:36 PM UTC
  • 186 views
jeroen
Forum|alt.badge.img+15
I'm working on a workflow that uses the PythonCaller to extract coordinates from a source file of my choice and puts them in a results attribute. My plan is to replace the existing geometry with the one extracted using the GeometryReplacer with the OGC WKT encoding.
As an example:
This format needs to go into the GeometryReplacer
LINESTRING(161274.467 453784.372,161277.253 453785.924,161279.958 453787.131,161280.921 453787.508)
What i got is something like this, but it could be longer or shorter but always has a x and y coordinate but rounding after the comma could be different:
161274.467 453784.372 161277.253 453785.924 161279.958 453787.131 161280.921 453787.508
How can you replace every second space with a comma without making it too static?This example contains four coordinates but it could have 8, 100 or more. After this stap i use LINESTRING(@Value(result)) to add the linestring text.
Best answer by takashi
Hi @JeroenR, if you prefer to use Python script, this code snippet might help you. Assuming that the attribute "poslist" stores the space separated coordinates.
    src = feature.getAttribute('poslist').split()
    result = ','.join(['%s %s' % c for c in zip(src[0::2], src[1::2])])
    feature.setAttribute('result', result)
The StringReplacer with a regular expression could also work.
  • Mode: Replace Regular Expression
  • Text To Replace: (\S+\s+\S+)\s+
  • Replacement Text: \1,
However, if the goal is to create a line geometry from the coordinates with the GeometryReplacer, GML format could also be used without replacing spaces with commas.
<gml:LineString>
  <gml:posList>@Value(poslist)</gml:posList>
</gml:LineString>
  • Dec 29, 2017 2:37 PM UTC
<gml:LineString>
</gml:LineString>
  • Dec 29, 2017 2:42 PM UTC
<gml:LineString>
</gml:LineString>
Corrected the Python codes example.
jeroen
  • Dec 29, 2017 2:49 PM UTC
<gml:LineString>
</gml:LineString>
Thanks a million! the GML trick did it :) I did not want any extra python cause of  support reasons. If needed now i can get coordinates in the WKT format with geometry extractor but for now this is not needed.
