folder existance checker
  • Mar 23, 2020 1:00 PM UTC
  • 11 replies
  • 171 views
Hello,
I am trying to use Python caller to check if a folder exist. Here is the code:
But it doesnt geve back outcome to attribute "van". Where is my mistake?
import fme
import fmeobjects
import os
def processFeature(feature):
    van = os.path.isdir(feature.getAttribute('_LAS_eleresiutvonal'))
    print van
    feature.setAttribute('_van', van)
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self,feature):
        self.pyoutput(feature)
    def close(self):
        pass
Best answer by ebygomm
The bit in yellow needs to be set to match the bit in red so processFeature
You are calling a class that doesn't exist
Forum|alt.badge.img+54
  • Mar 23, 2020 1:08 PM UTC
What version of python are you using? That code won't work for python 3
Have you enterd _van in the Attributes to Expose parameter
  • Mar 23, 2020 1:17 PM UTC
I tried it but it gives back missing values :
jdh
Forum|alt.badge.img+41
  • Mar 23, 2020 1:20 PM UTC
Is your class or function to process features set to processFeature (good) or FeatureProcessor (bad in this case)?
  • Mar 23, 2020 1:22 PM UTC
Is everything else set up exactly as the screenshot?
  • Mar 23, 2020 1:29 PM UTC
everything is okay, only python output is missing
  • Mar 23, 2020 1:52 PM UTC
In the above code, the lines 9-15 are not (should not be) used. Try deleting these lines and see if you get a different error message.
  • Mar 23, 2020 2:15 PM UTC
I deleted, now it says:
PythonFactory failed to load python symbol `FeatureProcessor'
Factory proxy not initialized
PythonCaller(PythonFactory): PythonFactory failed to process feature
  • Mar 23, 2020 2:20 PM UTC
If you look at the screenshot, you will see that class or Function to process feature is set to processFeature, and the additional unwanted code is deleted. If you set up your pythoncaller exactly as posted it will work
  • Mar 23, 2020 2:31 PM UTC
  • Mar 23, 2020 2:42 PM UTC
I got it, it works well ;)
Thanks, now we see the real error. Do as suggested by @ebygomm and it should work.
