FMEObjects Worker has stopped working
  • Feb 2, 2017 3:11 PM UTC
  • 251 views
Hello,
Recently updated FME 2015 to 2016 version. Whenever I open a dataset in Data Inspector the FMEObjects Worker error dialog opens up. The problem details are as below.
Problem signature:
Problem Event Name: APPCRASH
Application Name: fmeobjectsworker.exe
Application Version: 2016.7.23.16716
Application Timestamp: 5848cc28
Fault Module Name: python27.dll
Fault Module Version: 2.7.10150.1013
Fault Module Timestamp: 5560ad81
Exception Code: c0000005
Exception Offset: 0007d455
OS Version: 6.3.9600.2.0.0.272.7
Locale ID: 2057
Additional Information 1: 5861
Additional Information 2: 5861822e1919d7c014bbb064c64908b2
Additional Information 3: 1318
Additional Information 4: 13181ae637ac2592fac0ca2dd662cdcc
The Data Inspector however seems to be working fine after closing the dialog.
Thank you
Vidya
  • Feb 2, 2017 3:14 PM UTC
A few things to try when you get weird crashes like this:
  1. Reboot your pc
  2. If that doesn't work: Try running as local admin
  3. If that doesn't work: Re-install FME
That fixes most such problems, in my experience.
  • Feb 3, 2017 9:26 AM UTC
Hi @david_r Thanks for the suggestions but non of them worked. So as another option, I downgraded FME 2016 to build 16674 from build 16716. However, the problem still exists.
  • Feb 6, 2017 9:26 AM UTC
Did you try running FME with local admin privileges? How about trying to run FME on a different PC in the same network?
If nothing else works, consider contacting your FME reseller for support.
  • Feb 9, 2017 3:08 PM UTC
Hi @david_r, Tried it. I will get in touch with the FME reseller for support. Appreciate your assistance. Vidya
