FMEFlowLogFileRetriever no longer exists in FME 2025. How to use HTTPCaller to access Flow Rest API?
  • Mar 6, 2026 8:28 PM UTC
  • 101 views
aguan
Forum|alt.badge.img+11
My long time transformer friend FMEFlowLogFileRetriever is not avaliable in FME 2025. The error asked me to use HTTPCaller to retrieve the job log file. So I used this rest point in the HTTPCaller’s Request URL with GET - https://my-fme-flow-hostname/fmerest/v3/transformations/jobs/@Value(jobid)/log. I tried the Basic and Web Connection authentications, but both gives the error “HTTPCaller (HTTPFactory): An error occurred while accessing the URL 'https://my-fme-flow-hostname/fmerest/v3/transformations/jobs/98/log'”. I have no problem publishing using the same Web Connection for the authentication, so don’t understand what the issue is. The jobid = 98 was run successfully on the FME Flow.
Best answer by LizAtSafe
Hi ​@aguan, this article was written to replace the FMEFlowLogFileRetriever. https://support.safe.com/hc/en-us/articles/37184679562637-Retrieving-FME-Flow-Job-Logs-Using-the-REST-API-V4
LizAtSafe
Forum|alt.badge.img+26
  • Mar 6, 2026 8:41 PM UTC
aguan
  • Mar 9, 2026 1:30 PM UTC
​@LizAtSafe Thanks a bunch. I followed the article to replace the FMEFlowLogFileRetriever with HttpCaller and it worked. Great article with all the detail.
