FMECurve.snip() function deprecation
  • Apr 20, 2026 11:31 AM UTC
  • 5 replies
  • 131 views
Forum|alt.badge.img+63
Asking on behalf of a customer (but it may benefit others as well).
They've recently upgraded FME and get an error in a workspace log:
DeprecationWarning: FMECurve.snip() is deprecated and will be removed in a future release. Use FMEGeometryTools.snip() instead.
After some digging we found it's in a PythonCaller inside a Custom Transformer (the LineDivider, created by ​@takashi in 2014).
The Python code is;
import fmeobjects, math
class LineDivider(object):
def input(self, feature):
is3D = (feature.getAttribute('__linedivider.dim') == '3D')
mode = feature.getAttribute('__linedivider.mode')
value = float(feature.getAttribute('__linedivider.value'))
output = feature.getAttribute('__linedivider.output')
for attr in ['dim', 'mode', 'value', 'output']:
feature.removeAttribute('__linedivider.' + attr)
coordSys = feature.getCoordSys()
outputLines = output.startswith('Lines')
outputPoints = output.startswith('LinesAndPoints') or output.startswith('Points')
outputEndNodes = outputPoints and not output.endswith('ExceptEndNodes')
length = float(feature.performFunction('@Length(3)') if is3D else feature.performFunction('@Length(2)'))
numLines = int(round(value) if mode == 'ToNumber' else math.ceil(length / value))
len = value if mode == 'ToLength' else length / numLines
for (beg, end) in [(i * len, (i + 1) * len) for i in range(numLines)]:
geom = feature.getGeometry()
geom.snip(fmeobjects.SNIP_DISTANCE, is3D, beg, end if end < length else -1)
if outputLines:
line = feature.cloneAttributes()
line.setGeometry(geom)
line.setCoordSys(coordSys)
self.pyoutput(line)
if outputPoints and (0.0 < beg or outputEndNodes):
point = feature.cloneAttributes()
point.setGeometry(geom.getStartPoint())
point.setCoordSys(coordSys)
self.pyoutput(point)
if outputEndNodes:
point.setGeometry(geom.getEndPoint())
Any suggestions to where we need to change the Python code would be much appreciated 😇
Best answer by david_r
Try something like this, using the FMEGeometryTools.snip() method as suggested in the warning:
def __init__(self):
self.geomTools = fmeobjects.FMEGeometryTools()
segLen = value if mode == 'ToLength' else length / numLines
sourceGeom = feature.getGeometry()
for (beg, end) in [(i * segLen, (i + 1) * segLen) for i in range(numLines)]:
snipEnd = end if end < length else -1
snipped = self.geomTools.snip(
sourceGeom, fmeobjects.SNIP_DISTANCE, is3D, beg, snipEnd
if outputLines:
line.setGeometry(snipped)
self.pyoutput(line)
point.setGeometry(snipped.getStartPoint())
if outputEndNodes:
point.setGeometry(sourceGeom.getEndPoint())
def close(self):
pass
Caveat emptor: I haven’t tested it myself :-)
  • Apr 20, 2026 12:07 PM UTC
Interestingly, the current fmeobjects documentation does not mention the deprecation of the snip() method:
https://docs.safe.com/fme/html/fmepython/api/fmeobjects/geometry/_curves/fmeobjects.FMECurve.html#fmeobjects.FMECurve.snip
Neither does the FME deprecations page: https://support.safe.com/hc/en-us/articles/25407729702029-FME-Deprecations
Maybe reach out to Safe support for up to date information.
  • Apr 20, 2026 12:10 PM UTC
def __init__(self):
if outputLines:
self.pyoutput(line)
if outputEndNodes:
def close(self):
pass
Forum|alt.badge.img+54
  • Apr 20, 2026 1:55 PM UTC
Note, the python you’ve posted here is not the same as the python in the current iteration of the transformer (same error though).
Does the warning actually cause the job to fail if run on flow?
Thanks ​@david_r , we'll give that a try.
​@ebygomm I don't think it actually fails the workspace, it's a warning that the function will be deprecated in  a future release.
LizAtSafe
Forum|alt.badge.img+26
  • Apr 23, 2026 9:50 PM UTC
