FME2019.1: Unexpected behaviour of SpatialRelator - Attribute value handling
  • Oct 10, 2019 12:52 PM UTC
  • 6 replies
  • 101 views
Using FME2019.1 I get some unexpected behaviour of SpatialRelator3.
Instead of 'merging' values from SpatialRelator & SpatialRelator_2, FME seems to copy attribute values from one attribute to another. (see screenshot).
'grafnummer' & 'bloknummer' should have different attribute values but FME seems to 'copy' values for both attributes. This behaviour does not occur when running the workspace in 2018.
sigtill
Forum|alt.badge.img+25
  • Oct 10, 2019 2:11 PM UTC
Try to upgrade the transformer SpatialFilter in the Navigator window and see if this helps:
  • Oct 10, 2019 2:49 PM UTC
Thanks @sigtill but unfortunately same result (I tried to upgrade Spatial Relator instead of Spatial Filter).My workaround (at least for now) is to 'Generate List' within SpatialRelator, exposing all attributes. Next, I have exposed a 'relationship'-attribute value within the list holding the correct value and renamed it to the original attribute.
Forum|alt.badge.img+54
  • Oct 10, 2019 3:11 PM UTC
There were issues with the spatial relator and attribute handling but I thought they were resolved in 2019.1 Although this looks like a slightly different flavour
https://knowledge.safe.com/questions/86471/spatial-relator-attribute-handling-replacing-value.html
  • Oct 10, 2019 3:44 PM UTC
@egomm I hesitated to add my issue to that topic. Indeed this topic/outcome of SpatialRelator is somewhat different but it adds to the problem with this transformer within v2019. Maybe admin should merge this topic with yours.
fmelizard
Forum|alt.badge.img+22
  • Oct 10, 2019 11:42 PM UTC
Hi @gisaalter Please send your workspace and some sample data to https://www.safe.com/support/report-a-problem/ Thanks!
gio
Forum|alt.badge.img+15
  • Oct 11, 2019 10:18 AM UTC
previous issue (pointed out by @egomm ) was conflict between an operand and a non existing operand.
Logically that is no conflict, therefore the requestor prevails. I would say the transformer did it's intended job then (of course non intended result).
I wonder in this issue, as I've done it myself, is weather you should not clear the results of your previous relators.
Try removing the previous relators attributes prior to sending their results to the next.
