FME Workbench 2021.2 - Custom Transformer tabs are reordered randomly when reopening a workspace
  • Nov 27, 2026 10:07 PM UTC
  • 0 replies
  • 3 views
jeff_beaudry
I have an FMW containing four embedded custom transformers:
AAA
BBB
CCC
DDD
Immediately after creating them, the tabs appear as:
Main | AAA | BBB | CCC | DDD
After closing and reopening Workbench, their order changes.
For example, opening the exact same workspace multiple times produced:
Main | CCC | BBB | DDD | AAA
Main | DDD | CCC | AAA | BBB
Main | CCC | BBB | AAA | DDD
I also tested:
- changing the physical order of the <SUBDOCUMENT> blocks in the FMW
- changing the transformer IDENTIFIER values
- closing and reopening the tabs manually in the desired order
- opening copies of the exact same FMW
- opening Workbench with and without the Start tab
None of these controls the order reliably.
After saving the workspace, the physical order of the
<SUBDOCUMENT> blocks is rewritten to match the current tab order.
Is the ordering of embedded Custom Transformer canvas tabs
non-deterministic in FME Workbench 2021.2?
More importantly, is there a supported way to control this order,
and has this behavior changed in newer versions of FME Form?
