FME Server Python Error Logs
  • Mar 14, 2017 3:12 PM UTC
  • 5 replies
  • 157 views
clemensb
Forum|alt.badge.img+5
i have a Workspace which fails in FME Server. The "statusMessage= FME_END_PYTHON failure", but when I look into the log there is no Error and the last entrys are:
2017-03-14 15:36:53| 22.7| 0.0|INFORM|Translation was SUCCESSFUL with 0 warning(s) (56983 feature(s) output)
2017-03-14 15:36:53| 22.7| 0.0|INFORM|FME Session Duration: 26.5 seconds. (CPU: 19.8s user, 2.9s system)
Is there a log where the python error is logged?
I am pretty sure its because I am using Arcpy in my shutdown python script. When I use the Workspace in Desktop all is fine, but I am pointing to the right interpreter.
I found this article from Mark https://knowledge.safe.com/articles/814/choosing-a-different-python-interpreter-installati.html#heading_toc_j_9
with a link to the FME Server Administrators Guide to setup a Python Interpreter http://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/Configuring_Custom_Python_Interpreter.htm
but I get a Error 404 :(
Thanks for your help!
  • Mar 14, 2017 3:16 PM UTC
You can see some errors in the <ServerNamer>_fmeprocessmonitorengine.log file in the resources\logs\engine\current folder (look at lines 14+):
Fri-10-Mar-2017 03:25:12 PM   INFORM   FME2016-2_Engine2   393558 : Commencing startup of process "FME2016-2_Engine2". This is attempt 5.
Fri-10-Mar-2017 03:25:12 PM   INFORM   Thread-25   FME2016-2_Engine2                   FME 2017.0.0.0 (20170228 - Build 17259 - WIN64)
Fri-10-Mar-2017 03:25:12 PM   INFORM   Thread-25   FME2016-2_Engine2                             FME Engine (node locked-crc)
Fri-10-Mar-2017 03:25:12 PM   INFORM   Thread-25   FME2016-2_Engine2                           Machine host name is: FME2016-2
Fri-10-Mar-2017 03:25:12 PM   INFORM   Thread-25   FME2016-2_Engine2   Operating System: Microsoft Windows Server 2012 Server 4.0 64-bit  (Build 9200)
Fri-10-Mar-2017 03:25:12 PM   INFORM   Thread-25   FME2016-2_Engine2                    Copyright (c) 1994 - 2017, Safe Software Inc.
Fri-10-Mar-2017 03:25:12 PM   INFORM   Thread-25   FME2016-2_Engine2                                  Safe Software Inc.
Fri-10-Mar-2017 03:25:12 PM   INFORM   Thread-24   FME2016-2_Engine1   FME_SHARED_RESOURCE_DIR is unset
Fri-10-Mar-2017 03:25:12 PM   INFORM   Thread-24   FME2016-2_Engine1   FME_SHARED_RESOURCE_DIR has been changed and is now 'C:/FMEServerShare///resources/engine'
Fri-10-Mar-2017 03:25:13 PM   INFORM   Thread-26   FME2016-2_Engine2   FME_SHARED_RESOURCE_DIR is unset
Fri-10-Mar-2017 03:25:13 PM   INFORM   Thread-26   FME2016-2_Engine2   FME_SHARED_RESOURCE_DIR has been changed and is now 'C:/FMEServerShare///resources/engine'
Fri-10-Mar-2017 03:25:42 PM   INFORM   Thread-24   FME2016-2_Engine1   Translation was SUCCESSFUL
Fri-10-Mar-2017 03:25:42 PM   INFORM   Thread-24   FME2016-2_Engine1   Traceback (most recent call last):
Fri-10-Mar-2017 03:25:42 PM   INFORM   Thread-24   FME2016-2_Engine1     File "<string>", line 5, in MF_Include_1489177542141
Fri-10-Mar-2017 03:25:42 PM   INFORM   Thread-24   FME2016-2_Engine1     File "<string>", line 3, in ParamFunc
Fri-10-Mar-2017 03:25:42 PM   INFORM   Thread-24   FME2016-2_Engine1     File "C:\FMEServerShare\resources\engine\Transformers\Tools.py", line 10, in <module>
Fri-10-Mar-2017 03:25:42 PM   INFORM   Thread-24   FME2016-2_Engine1       import cx_Oracle
Fri-10-Mar-2017 03:25:42 PM   INFORM   Thread-24   FME2016-2_Engine1   ImportError: No module named cx_Oracle
Fri-10-Mar-2017 03:25:42 PM   INFORM   FME2016-2_Engine1   393656 : Process "FME2016-2_Engine1" being restarted.
Fri-10-Mar-2017 03:25:42 PM   INFORM   FME2016-2_Engine1   393566 : Process "FME2016-2_Engine1" waiting for process output listener threads to terminate...
clemensb
  • Mar 14, 2017 3:21 PM UTC
Thank you i found it!
And its like i supposed: ImportError: No module named arcgisscripting
Do you know how to change the interpreter?
  • Mar 14, 2017 3:34 PM UTC
Try this link: Using python with FME Server
  • Mar 14, 2017 3:39 PM UTC
@larry is right about the log file, you will find it in the admin interface under Resources / Logs / engine / current.
You can use the excellent traceback module to include a detailed error message in the actual job log.
Here's an example shutdown script:
import traceback
import fme
try:
    # Your code here
    test = 1 / 0
except:
    with open(fme.logFileName, 'a') as fmelog:
        # Re-open FME log file in append mode
        fmelog.write("An error occurred in the shutdown script:\n")
        fmelog.write("-" * 75 + '\n')
        fmelog.write('\n'.join(traceback.format_exc().splitlines()) + '\n')
    raise # Re-raise the original exception
Result from the end of the job log:
clemensb
  • Mar 15, 2017 9:53 AM UTC
import traceback
import fme
try:
    # Your code here
    test = 1 / 0
except:
Very nice solution!
