FME Server Express Installation - Would there be any issue setting up the System File Share on the D drive while keeping the destination folder as C:\\Program Files...?
  • Dec 12, 2022 7:25 PM UTC
  • 29 views
On the VM there is a C drive with 80 GB on the C drive and 80 GB on the D drive. Wanting to ensure we don't run into any issues.
matt.m-at-safe
Forum|alt.badge.img+14
Hi @bibold​, if the drive is on the same machine, then you shouldn't have an issue. Only when the System Share is installed in a different location on the network do additional considerations need to be taken.
