FME Server: data upload through web application incl. authentication
  • Apr 18, 2018 12:12 PM UTC
  • 87 views
lazarlubomir
Forum|alt.badge.img+11
Hello,
please, I created web application according to this manual: https://knowledge.safe.com/articles/583/data-upload-part-3-rest-api.html. Everything is ok, but I need to user to authenticate firstly before he can run the workspace. Is it possible? I dont want to user had to open FME Server web interface and authorize there, I can do it only on created web application.
Thank You so much for ideas!
Lubo
Best answer by gerhardatsafe
Hi @lazarlubomir
you can implement authentication for your data upload app with the FME Server Token Service. At the bottom this page you will also find a code snippet of an example using JS to retrieve a token using FME Server Token Service:
https://playground.fmeserver.com/getting-started/authentication
I hope this gets you started!
Hi @lazarlubomir
lazarlubomir
  • Apr 18, 2018 7:50 PM UTC
@GerhardAtSafe
Thank You so much, it started me! :-)
Lubo
