FME quick translator; how to not change position of attributes of blocks during transformation from one coordinate system to another
  • Apr 3, 2020 7:38 AM UTC
  • 43 views
During transformation, I don't want to change the position of attributes of blocks from Autocad.
daraghatsafe
Hey @maloks, would you be able to share your dwg?
Also, does the dwg have a coordinate system set before the translation?
What coordinate system are you trying to reproject the drawing to?
Have you tested the translation using Workbench instead of the Quick Translator to see if there is any difference in the results?
