fme pdf reader fatal error
  • Mar 7, 2019 4:40 PM UTC
  • 120 views
oliver.morris
Forum|alt.badge.img+14
I am trying to read in some pdfs, unfortunately when the pdf reader fails to open the pdf (if say it is corrupt) the workbench stops:
2019-03-07 15:40:24| 391.6| 0.0|FATAL |PDF Reader: Failed to open document '\\xxxx.pdf' because the file is not in PDF format, or because it is corrupted
I have set the workbench to ignore failed readers and continue transaction is setup under the Rejected feature handling.
Is there any way I can keep it running?
Thank you
Oliver
Best answer by david_r
You can wrap your workspace in a second workspace that uses the WorkspaceRunner transformer, passing the PDF filename as a published parameter.
  • Mar 7, 2019 4:46 PM UTC
oliver.morris
Will give that a spin. Thank you
