FME oracle DATABASE Connection issue
  • Jan 29, 2019 12:15 PM UTC
  • 176 views
f.kemminje
Forum|alt.badge.img+11
I created the oracle connection inside named connection window. and tested, its good. But when i use the same connection for sql executor i am getting the following error
Connecting to ORACLE database `EGIS_T' with user name of `EGIS' and password of `***'
Error connecting to Oracle database: message was `ORA-12154: TNS:could not resolve the connect identifier specified'. (serverType=`ORACLE8i', serverName=`EGIS_T', userName=`EGIS', password=`***', dbname=`')
ORACLE Reader: Using Oracle Reader to read tables from database `', server type `ORACLE8i', server name `EGIS_T', user name `EGIS', password `***'
ORACLE Reader:
fme is not mapping the connection name to connection object.
where is the problem ?
  • Jan 29, 2019 12:45 PM UTC
Sounds like an Oracle client configuration issue. Have you got a tnsnames.ora file with a defintion of EGIS_T?
What happens if you execute the following on the command line:
tnsping EGIS_T
You will need the full Oracle client for this (the instant client does not include tnsping, I believe).
See also this article:
https://knowledge.safe.com/articles/130/how-to-setup-an-oracle-instant-client-for-use-with.html
