FME London Survey Grid
  • September 8, 2017
  • 129 views
hello,
I am looking at converting from British National Grid to London Survey Grid,
I have looked in the pre-defined Coordinate systems within FME and struggle to find this grid,
the conversion figures are provided in this PDF on page 17 Table 1,
as i am new to this kind of data, how would i go about using those figured to create a custom coordiatie system in FME?
any help would be much apreseated
cheers,
James
http://www.engineeringsurveyor.com/software/1-026%20-%20Topographical%20Surveys%20and%20Mapping.pdf
davideagle
Forum|alt.badge.img+22
  • September 8, 2017
Hi James - It is possible with FME but you will have to use a specific sequence of transformers, including the GridInquest transformer, as well as defining a custom coordsys name. Perhaps best to direct message me on david.eagle@1spatial.com as you perhaps ought to talk to TfL to assist and I can put you in touch with the correct person.
