FME Form 2022 not able to read DGN V7/8 files
  • Sep 11, 2023 3:14 PM UTC
  • 7 replies
  • 142 views
galigis
Forum|alt.badge.img+22
Hello,
Has anyone faced issues while trying to read DGN files (V7 or V8) in FME 2022? My current version is FME(R) 2022.2.5.0 (20230329 - Build 22795 - WIN64). Below an screenshot of the error:
imageI have tried to changed the reading parameters but still unable to read it. Also I have loaded the same DGN onto FME 2020 and works fine.
Can this be a bug in the 2022 version?
saraatsafe
Forum|alt.badge.img+13
  • Sep 13, 2023 6:06 PM UTC
Hi @galigis​, I wasn't able to reproduce your error message in FME 2022.2. Would you be able to share your data? I can try reading it in to double check that it's not an issue with your data. If possible, it would also be helpful if you could share your workspace or a screenshot of your reader parameters so I can take a look.
galigis
  • Sep 14, 2023 8:02 AM UTC
Thanks @saraatsafe​ , Attached a simple dgn file for you to test. FME gives me an errors when trying to load it in 2022.2 while it works fine in 2021 for example.
Also below an example of the reader parameters, I've only changed the Group Element By to Scheme -Level names:
imageCheers
saraatsafe
  • Sep 15, 2023 5:32 PM UTC
imageCheers
Hi @galigis​​, it seems to me that FME has trouble opening your DGN file in 2022.1 onwards, as I was able to read it in using FME 2022.0 and 2021.2. I didn't have any issues with another DGN file that I had on hand, so I suspect there's something up with your file, or perhaps something was implemented in 2022.1+ that doesn't mesh well with your file. I've filed a ticket (internal reference: FMEENGINE-80399) so one of our developers can further investigate.
saraatsafe
  • Sep 15, 2023 8:20 PM UTC
Hi @galigis​, update on that ticket: this looks like this is a bug with one of our 3rd party libraries. We can share this with their developers so they can take a look, but we'll first need you to consent to us sharing your Dummy_DGN.dgn file with them. Please let me know!
galigis
  • Sep 18, 2023 6:18 AM UTC
Thanks for the update @saraatsafe​ , yes please share the dgn file for them to have a look. There must be a bug in the ME(R) 2022.2.5.0 (20230329 - Build 22795 - WIN64) version, so it would be good to know how to fix it. cheers
galigis
  • Sep 25, 2023 5:23 PM UTC
Hello @saraatsafe​ , any update on this ticket?
saraatsafe
  • Sep 25, 2023 6:49 PM UTC
Hi @galigis​, we have notified the developers of the 3rd party library and sent them your file, but we haven't received a response yet. Thanks for your patience on this!
