FME download service seems to discard zipped outputfiles
  • Nov 26, 2019 2:46 PM UTC
  • 9 replies
  • 213 views
thijsknapen
Forum|alt.badge.img+12
On FME Server I am not able to obtain a zipped output file within the data download url. In the log it does show that the file is created, but it doesn't return in the download url.
So to clarify, say I create a couple of files in my workbench:
1. file1.csv
2. file2.zip (directly containing e.g. file1.csv)
3. file3.txt
When I run the workspace locally, all of the files are created and placed in the specified outputfolder. If however I publish the workspace to FME Server I obtain a download link to a zipfile that only contains file1.csv and file3.txt
Any ideas on what I'm doing wrong? Or is it maybe just not possible to use the data download service in combination with zipped output files?
N.b. From browsing the forum, maybe the issue is related to: https://safesoftware.cloud.answerhub.com/questions/93696/fme-datastreaming-not-returning-zip-file.html
Best answer by helmoet
Hi @thijsknapen, you could try generating all output using FeatureWriters (or using FMEServerJobSubmitter with your original workspace). After that you could gather the results using a FeatureReader, choosing for Format "Directory and File Pathnames" and for Folder the directory you created the files in. After that connect a FileCopy writer that will be the only writer configured in the DataDownload service. The data download link will contain all files written by the filecopy writer, including zip files.
jdh
Forum|alt.badge.img+41
  • Nov 26, 2019 3:41 PM UTC
When publishing the workspace to the server, there is a setting on the DataDownloadService about the writers to include in the zip. Do you have all the writers selected?
thijsknapen
  • Nov 26, 2019 3:47 PM UTC
Hi jdh, Thanks for the reply. In response; Yes, i did. I have three featurewriters, and all of them are selected. Today also discovered the following topic: https://knowledge.safe.com/questions/82459/how-can-i-change-the-folder-structure-returned-in.html, and tried to see whether that could solve the issue (e.g. specifiing "\\file2.zip" or "/file2.zip" or "\\file2.zip\\" after clicking on 'More'), but unfortunately without succes.
Hi @thijsknapen,
This is a shortcoming of FME Engine and how it unable to write a zip file within a zip file (issue reference: FMEENGINE-48120). In FME Desktop if you were to change the Destination path for any zipped writer so that it was being written into another zipped file then whilst the translation would succeed when you go to view the result you'll find the bottom level file is correctly zipped it is actually being stored in a folder that just has .zip in the name rather than a second zipped file.
When you select the Data Download Service in FME Server the engine has to zip up the result in order to produce the URL, in your scenario it is attempting the same thing outlined above and so, since the top layer actually a folder rather than a file, the Data Download URL cannot be created.
Therefore in order to receive the data download link none of the writers selected to be included can be outputting to a zip file.
helmoet
Forum|alt.badge.img+8
  • Nov 27, 2019 6:27 PM UTC
thijsknapen
  • Nov 28, 2019 9:55 AM UTC
Hi @helmoet, Tnx for the suggestion. I already used featurewriters in the 'inflicted workspace', so I'll definitely give it a try!
thijsknapen
  • Nov 28, 2019 10:04 AM UTC
Hi @thijsknapen,
Hi @hollyatsafe, thanks for the feedback. I was already afraid that the root issue would be in respect to nested zips. However, so far I didn't understand why that would be an issue. As i'm always also interested in the how/why of things, I greatly appreciate the given explanation. N.b. Is this issue also documented in some place, i.e. could I have known upon reading some documentation page?
thijsknapen
  • Nov 29, 2019 8:15 PM UTC
Hi @helmoet. I tried to follow your method today, but unfortunately without succes. I was able to use the fileCopy writer and have been able to verify that the files were indeed copied to the newly desired 'copyFolder' (I am able to access the FME Server over the network, and can see that the files are indeed copied to the new directory). However, selecting only the filecopy writer to be outputted in the data download, I obtain an empty zip. This also occurs when I only select e.g. only a .xlsx file to be copied to the new 'copyFolder'... Any ideas on what I'm doing wrong?
thijsknapen
  • Nov 30, 2019 11:25 AM UTC
Hi @helmoet. I managed to make the 'filecopy method' work today. The missing link was that I discovered from the following topic https://knowledge.safe.com/questions/60007/why-cant-filecopy-writer-output-be-included-in-the.html that upon using FME Server you need to use relative file path(s) for the 'filecopy_dest_dataset' attribute in order for its output to return in the data download service.
Hi @thijsknapen,
I apologise for not responding sooner - I somehow missed this reply. I'm happy to say that a fix has gone into FME 2020 beta b20146 (safe.com/beta) to allow for nested zipping and this now means it is possible to use the Data Download Service to write out zipped datasets.
As for the documentation I'm not aware that this was recorded anywhere, we do not tend to backport issues in our documentation and since this has been fixed for 2020 there is no requirement to add this any longer. Thanks to your post this information is now available on our Community so hopefully if anyone else encounters this problem they will find this post!
- Thanks, Holly
