FME Desktop 2022: How to specify the type of created attribute field (chr, double, integer, etc.)?
  • Mar 6, 2022 5:28 PM UTC
  • 12 replies
  • 1505 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out how to specify the type of the attribute field
In the screenshot below, I created the “AreaPercent” attribute but couldn’t figure out how to specify its type. However, as it’s written in a feature class geodatabase, it’s considered as “chr”.
How this can be managed?
Clip_183
Clip_184
connecter
Forum|alt.badge.img+10
  • Mar 7, 2022 7:51 PM UTC
Hi @jamal​,
do you need the Automatic Attribute Definition? You can change the type at the Manual option. Here is an idea to handle it within the AttributeManager:
AC Idea: Set Data Type option within the AttributeManager (safe.com)
jamal
  • Mar 8, 2022 4:42 AM UTC
I tried the suggestion proposed by bleutzinn but appears not to work with me.
What could be the issue here?
Clip_188
Clip_189
jamal
  • Mar 8, 2022 8:38 AM UTC
Despite the fact that the "user parameter" is seletced with "number type, it fails to be wittern in the file geodatabase as number
Clip_197
Clip_196
Clip_198
Forum|alt.badge.img+63
Clip_197
Clip_196
Clip_198
If you switch the Attribute Definition to Manual (in your writer feature type) you'll be able to change attribute types. Internally FME is pretty flexible with attribute types, it's only really handled on the writers.
jamal
  • Mar 8, 2022 10:01 AM UTC
But I need to have the writer to be dynamic but not manual so that all changes made at the level of attribute manager are reflected directly on the writer
Clip_207
Clip_207
That's why you need to do that as the very last step of your workspace design process. If you leave it on automatic FME will do a best guess based on the workspace to what those types should be, but you as a designer know that much better. One of the things you'll see is that a lot of your attributes are set to char(200), which is almost certainly going to be way too much.
jamal
  • Mar 8, 2022 10:15 AM UTC
It would be much more powerful if we get the chance to specify the field type as it's created. This way all should work fine
But you can specify it. On the writer feature type.
jamal
  • Mar 8, 2022 10:38 AM UTC
Then how to work on this case:
In the screenshot below, I'm converting data from AutoCAD that represents the Area. Then how the FME can understand this data as number so that i can apply calculations?
Attached
Clip_210
Clip_211
Attached
Clip_210
Clip_211
If it's a number, you can do calculations on it. If not, then not. I used an AttributeCreator to create a new attribute and filled it (using the Arithmetic Editor, otherwise you'll get a text string) with a new calculated value
Screenshot 2022-03-08 at 11.54.15Screenshot 2022-03-08 at 11.54.25If FME can't make a number out of it and you try and do calculations it'll fail (or more precisely, it'll return <null>), so if there is a likelihood of the texts not all being numbers you'll need to account for that, for example with an AttributeValidator
jamal
  • Mar 8, 2022 12:41 PM UTC
Thanks for the approcah
FME gets them as numbers (which is good for me), nevertheless, they are aligned left in the column as if they are Texts!
Clip_217
Clip_217
Yes. But they are numbers. Internally, FME does not really care that much. If it looks like a number FME can treat it like a number.
