FME Desktop 2022 Build 22304: “GeometryFilter” with and without “GeometryValidator” prior to it shows different results considering that nothing is repaired,
  • Mar 20, 2022 8:21 PM UTC
  • 54 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out why “GeometryFilter” with and without “GeometryValidator” prior to it shows different result considering that nothing is repaired.
How come a “multiarea” is detected if the “GeometryValidator” is run before the “GeometryFilter” but never identified if the “GeometryFilter” is run without “GeometryValidator” prior to it?
What could be the issue here?
The data is attached
Clip_292
danilo_fme
Forum|alt.badge.img+58
  • Mar 20, 2022 10:41 PM UTC
Hi @jamal​
What kind of configuration you did on transformer GeometryValidator?
Thanks in Advance,
Danilo
jamal
  • Mar 21, 2022 4:52 PM UTC
The settings are as per the screenshots below
Clip_295
