fme_dataset is not changing for different schemas
  • Mar 25, 2025 12:40 PM UTC
  • 106 views
salah.elfarissi
Forum|alt.badge.img+3
Hello,
I am reading a folder with two shapefiles.
I am exposing fme_dataset.
fme_dataset takes the first values of the two shapefiles and does not change.
I’m using FME(R) 2024.2.3.0 (20250130 - Build 24825 - WIN64
kailinatsafe
Forum|alt.badge.img+24
Hello ​@salah.elfarissi, thank you for reporting this behaviour. I think I was able to reproduce the issue in FME Form 2025.0 & 2024.2.3. Moving forward, we can refer to this issue as FMEENGINE-86343. I assume this image is the output of a SchemaScanner? If so, to workaround the issue for the time being, you should be able to get results by using groupBy on fme_feature_type in the SchemaScanner. Let me know if you have any questions or need help applying a workaround. Happy to help, Kailin.
salah.elfarissi
Hello, sorry for the late reply.
Actually this come directly from the Feature Reader schema port.
