FME - CSV writer - why can i only see vchar as a field datatype, when i need char?
  • November 24, 2023
  • 10 views
matt_ccc
Looking to create a csv output as a 'dat' file for import to another system. basically rows of text with the fields essentially defined by the number of characters they occupy in the row, padded as necessary. So, i need the output row length to be fixed for each field, and yet I only have the otpion of vchar.
In online documentation I can see reference to a datatype of char, but this is not exposed in the fme writer.
Why is it missing? / Why have I missed it?
Help appreciated.
Using FME Desktop 2022.1.2.0
  • November 24, 2023
Hi @matt_ccc​ ,
If you intend to create a column aligned (column width fixed) text format dataset, I don't think using CSV writer is the best way.
I would recommend you to firstly make each column text appropriate width with StringPadder(s), concatenates all of them into a single string with StringCocnatenator etc., then write the concatenated string into a 'dat' file with Text File writer or Data File writer.
Hope this helps.
