FME Can deal with registry data ? ex : HKEY_CURRENT_USER key and values data
  • Oct 23, 2017 6:29 PM UTC
  • 48 views
Useing FME desktop Can i read and write "HKEY_CURRENT_USER" data ?
I need Created the key at run time and set the value according i will read the parameter values.
Best answer by brianatsafe
Hi @kumarc,
You can use a python library with the PythonCaller to do this. For example, the WinReg Module has tools to access and edit the Windows Registry.
See:
https://docs.python.org/2/library/_winreg.html#module-_winreg
brianatsafe
Forum|alt.badge.img+13
  • Oct 23, 2017 11:30 PM UTC
Hi @kumarc,
See:
