FME and Autodesk Recap RCP and RCS files
  • Sep 19, 2025 2:39 PM UTC
  • 222 views
mihaelad
Participant
FME can currently read from Autodesk Recap RCP and RCS files ?
alyssauatsafe
Forum|alt.badge.img+11
Hi ​@mihaelad
Just want to correct the previous post. The Recap writer came out in FME 2024.2 however the writer does not exist.
There is no Autodesk ReCap (RCP/RCS) reader in FME, which means you cannot directly open/import RCP or RCS files into FME.
If you have point cloud data in ReCap, you’ll need to export it to another supported point cloud format (e.g., E57, LAS, LAZ, XYZ) from ReCap itself, and then bring that into FME.
