FME 2024 FeatureReader - Constraint - Feature Types to Read - File Geodb - ALL or NONE
  • Oct 31, 2024 7:24 PM UTC
  • 90 views
jpaixao_cwl
Forum|alt.badge.img+5
Build 24627
Hello,
I am having issues reading a single Feature Type while using the Constraints in the FeatureReader transformer with both the File Geodb and the File Geodb API formats. Each of the Feature Types are visible when clicking on the ellipses; however, after you select one or multiples, the transformer updates and the only outputs are Schema, Generic, and Initiator.
There is a workaround, to not select a Feature Type to Read, however, this will then read all of the feature classes in the File Geodatabase.
Thanks,
Justin
jpaixao_cwl
  • Oct 31, 2024 7:28 PM UTC
My bad, the transformer hadn’t been upgraded.
