FME 2020 Bug: RasterExtentsCoercer removes attributes prefixed with underscore
  • May 7, 2020 11:23 AM UTC
  • 46 views
It seems that the RasterExtensCoercer removes every attribute which name is prefixed with underscore, if you set Raster Extent or Data MBR Extents to the Extents Type parameter.
See the attachment. (FME 2020.0.1)
  • May 12, 2020 9:54 AM UTC
@danatsafe, could you please take a closer look at this?
fmelizard
Forum|alt.badge.img+22
  • May 13, 2020 6:58 AM UTC
@takashi Unfortunately this is a known issue, FMEENGINE-57351. Thanks for the reminder.
  • May 13, 2020 7:09 AM UTC
@danatsafe, thanks for your notification. Hope this will be fixed in the near future.
