FME 2019 stability issues?
  • Apr 11, 2019 2:29 PM UTC
  • 26 views
miquelrs
Forum|alt.badge.img+10
I'm new to FME. Just upgraded to FME2019 and since then seems that stability issues have multiplied. Workbenches that worked fine, not crash in the middle of the process. Most of the issues seem to be related with temp files. Provably FME is trying to go through temp files stored in the previous version?
Are there any recommendations you would make in order to prevent these errors from happening? Maybe making a clean-up of FME temp files?
jatoxa
Forum|alt.badge.img+12
  • Apr 11, 2019 2:46 PM UTC
Hi @miquelrs
I also run 2019 and I have only gotten rock solid performance across most workspaces. What are you doing in the workspaces that causes problems?
Have you tried Tools>Purge Temporary Files?
You could also try setting a different FME temp folder under Windoes environment variables.
https://knowledge.safe.com/articles/176/fme-temp-environment-variable.html
/Jacob
