FME 2019.0: BulkAttributeRenamer seems to be broken
  • Apr 11, 2019 11:41 PM UTC
  • 28 views
Hello,
The BulkAttributeRenamer in FME 2019.0 build 19238 seems to have some issues. For example,
  • Regular Expression Replace: Backreferences (back slash and number) won't be replaced with the referenced sub-string.
  • Attribute Name containing Multibyte Characters: The attribute value won't be assinged to the renamed attribute.
See also the attached workspace:
Workbench interface looks fine, but...
the result is wrong.
In the example above, the resulting feature should have these attributes.
NameValueTEAM12345prefix_?a?_sufixb
  • Apr 13, 2019 9:50 AM UTC
Found another issue. This workspace won't complete the translation.
b19238-bulkattributerenamer-issues-2.fmwt (FME 2019.0 build 19238, Windows 10)
