FIs this a bug on FME(R) 2023.1.1.1?
  • Apr 25, 2024 8:21 PM UTC
  • 74 views
dpradhan_rvc
Observer
Forum|alt.badge.img+3
I’m using FME(R) 2023.1.1.1. I’m trying to filter some data using Tester and I used IN with a parameter has 2 items both of which are present in my dataset.
But the tester filters just 1 record. Why is that?
crystalatsafe
Forum|alt.badge.img+32
Hi @dpradhan_rvc
Try removing the space after the comma. That should hopefully work.
Crystal
