Finding gaps in a list
  • Jul 18, 2019 2:55 PM UTC
  • 10 replies
  • 178 views
Dear FME community,
I have a aggregated line with a list that looks like this:
_agg_{0}.begin = 0
_agg_{1}.begin = 100
_agg_{0}.end = 100
_agg_{1}.end = 200
The above one is the ideal, correct one. Unfortunately, not all data looks like this. Here two examples.
1) I want to find gaps with no data, for example:
_agg_{0}.begin = 0
_agg_{1}.begin = 102
_agg_{0}.end = 98
_agg_{1}.end = 200
2) If possible also overlapping data, for example:
_agg_{0}.begin = 0
_agg_{0}.end = 102
_agg_{1}.end = 200
The values from begin(+1) should be exactly the same value as end(0) and so on.
Any ideas how to solve this?
Many thanks and kind regards
Thomas
erik_jan
Forum|alt.badge.img+26
  • Jul 18, 2019 3:45 PM UTC
For this example you could use a Tester transformer with clause:
@Value(_agg_{0}.end ) = @Value(_agg_{1}.begin)
All examples that do not match this will come out of the Failed port of the Tester.
  • Jul 18, 2019 3:57 PM UTC
Thank you, but this will only test for the first and second entry of the list. Do you know how I can test for the hole list, i.e. with n number of elements?
Forum|alt.badge.img+54
  • Jul 18, 2019 4:43 PM UTC
You could explode the list and then use adjacent attribute handling to flag where the end value of one feature doesn't match the beginning value of the adjacent attribute.
If you don't want to explode the list, you're probably looking at a python solution
erik_jan
  • Jul 18, 2019 5:54 PM UTC
I created a workspace (FME 2019) that loops through the list and executes the test.
It is attached here: Begin_End_Tester.fmw
jdh
Forum|alt.badge.img+41
  • Jul 18, 2019 6:57 PM UTC
That would be my non pythonic solution too. With a caveat that I would probably sort the list by _agg{}.begin prior to exploding.
erik_jan
  • Jul 18, 2019 7:01 PM UTC
Have a look at my attached workspace.
No need for Python or exploding the list.
I used a Loop to find the gaps.
jdh
  • Jul 18, 2019 7:13 PM UTC
I find that looping through a list tends to be slower than exploding it, as long as you don't need to recombine the features.
Perhaps more relevant, the loop exits at the first failure, whereas the above method should identify all failures. I can't say which is better behaviour for the needs of the OP, if a pass/failure is all that's required, the efficiency of exiting the test sooner will make up for the looping overhead.
  • Jul 18, 2019 7:20 PM UTC
I've assumed the solution would need to flag which list elements have gaps/overlaps between them rather than just flagging if the list has gaps
I'd probably stick with python to avoid exploding the list, something like
import fme
import fmeobjects
def processFeature(feature):
    agg = list(zip(feature.getAttribute('agg_{}.begin'),feature.getAttribute('agg_{}.end')))
    gaplist = []
    for i, (a, b) in enumerate(agg[:-1]):
        if b != agg[i+1][0]:
            gaplist.append(str(i)+'-'+str(i+1))
    feature.setAttribute('issues',','.join(gaplist))
  • Jul 19, 2019 2:50 PM UTC
Hi @thomask, excellent answers has been provided already but I would add another approach.
In most cases, a Loop can be replaced with feature cloning. See this article: The Cloner-Loop Technique: FME and a Soccer Fan’s Travels
This workspace will store the gap between "_agge_{i}.begin" and "_agge__{i-1}.end" into "_agge_{i}.gap" (0 < i, "_agge_{0}.gap" will always be 0).
finding-gaps-in-a-list.fmwt (FME 2019.1)
  • Jul 22, 2019 10:58 AM UTC
Many thanks for all your help! I will look up the answers and let you know as soon as I have tested.
