Find correct set of points based on line attribute
  • Oct 23, 2017 2:45 PM UTC
  • 96 views
i have chopped up a set of lines into signal circuits which seems to be working great. Each signal circuit has two signals that define the begin and end of a circuit(with an associated attribute that should identify which circuit it belongs to). The issue I'm having is that there are two points in exactly the same location, one that has a corresponding attribute with the previous signal circuit and one that corresponds with the following signal circuit. I need to match an attribute of the circuit to the points so that i can bring some attributes from the point into the correct signal circuit.
danilo_fme
Forum|alt.badge.img+58
  • Oct 23, 2017 4:35 PM UTC
Hi @jonlibby,
Could you share us a sample your data?
Thanks,
Danilo
  • Oct 27, 2017 2:58 PM UTC
FME Script and Data attached. Let me know if you need any further explanation.signal-sections.fmwwoodtopw-track.zipisulated-joints-2-w-lat-long-jc.csv
@jonlibby Thanks for including your data. Can you expand on the rule for allocating the point to the correct circuit segment? In your workspace, the PointOnAreaOverlayer splits each circuit into segments. All those segments have the same attributes. What attribution on the point (CSV) features indicates whether it's the the upstream vs. the downstream line segment. What attributes are you trying to transfer to the segments? For example, records 93/94 in your CSV file are that the same location and seem to have the same attribute values.
