final challange basic training course
  • September 15, 2017
  • 9 replies
  • 53 views
northswejohan
Participant
I have a problem with the final challange in the basic training course 2017
When opening FinalChallenge.ffs i get an error message Is this a problem with incorrect password in the .ffs file or a problem that we can solve by ourself?
Best/
Johan
Best answer by LizAtSafe
Hi @northswejohan, in order to get the password for the final challenge, you need to complete each of the challenges before it. Completing these in order will give you the password for the FFS file. That's why it is a challenge!
Good luck!
-Liz
danilo_fme
Forum|alt.badge.img+57
Hi @northswejohan,
I dont believe the problem is password. Could you send me this file .ffs?
Thanks,
Danilo
LizAtSafe
Forum|alt.badge.img+25
Good luck!
-Liz
northswejohan
Participant
  • Participant
  • October 6, 2017
finalchallenge.zip
Hi! Here is the .ffs file. code is 6913 to open it.
Best/
Johan
danilo_fme
  • October 6, 2017
finalchallenge.zip
Best/
Johan
Hi @northswejohan, did you try to do what @lizsanderson did suggest you above?
Thanks,
Danilo
northswejohan
Participant
  • Participant
  • October 6, 2017
Yes thats how I got the code, but how do I apply it to the .ffs file. Or is this not possible? Best
danilo_fme
  • October 6, 2017
Perfect @northswejohan,
Select the Reader and set your FFS datase:
In Parameters option you insert the password:
Please, write me after if its works.
Thanks,
Danilo
danilo_fme
  • October 6, 2017
Thanks,
Danilo
northswejohan
Participant
  • Participant
  • October 6, 2017
Thanks,
Danilo
Thanks, it works.
danilo_fme
  • October 6, 2017
Thanks, it works.
Great. I'm happy to help
Thanks, Danilo
