Hello. I have a question about one solution. I have duplicate points with the same name, but with at least different geometry. I need to filter these duplicate points relative to this one coordinate. Passed will be the point with the same name that is closer to this coordinate. I am attaching the fmwt. Thank you very much.
Filtering based on geometries
Best answer by DanAtSafe
Hi @fmesafe.podpora What is the name that should match? Will a NeighborFinder work for you? Group by the name, generate a list, then sort by _distance with a ListSorter.
