Filtering based on geometries
  • Apr 18, 2023 3:37 PM UTC
  • 79 views
fmesafe.podpora
Forum|alt.badge.img+11
Hello. I have a question about one solution. I have duplicate points with the same name, but with at least different geometry. I need to filter these duplicate points relative to this one coordinate. Passed will be the point with the same name that is closer to this coordinate. I am attaching the fmwt. Thank you very much.
Best answer by DanAtSafe
Hi @fmesafe.podpora​ What is the name that should match? Will a NeighborFinder work for you? Group by the name, generate a list, then sort by _distance with a ListSorter.
DanAtSafe
Forum|alt.badge.img+23
  • Apr 18, 2023 11:59 PM UTC
fmesafe.podpora
Hi @danatsafe​  Thanks for the reply. I have point names that cannot occur more than once - attachment points_duplicity. I need to filter these points with the same name so that only one of them is output (the one that is closer to the created point - the output of the vertexCreator transformer). For example (in the attachment):
Point A1 and point A1 have the same designator (they have a duplicate name). Of these two points, only the one closer to the created point will be valid.
I need the same method for all 80 points - the point created is still the same.
I tried neighborFinder but _distance is the same for duplicate points - in fmwt.
fmesafe.podpora
Hello DanAtSafe. I would like to ask, do you know how to solve the situation? I have tried to add more information below.
Thank you very much
