Filtering based on attribute values
  • Jun 16, 2021 12:53 PM UTC
  • 802 views
fmesafe.podpora
Forum|alt.badge.img+11
Hello. I have a question. Is there a transformer that can filter based on attribute values? Something like SpatialFilter, but without spatial data. I have two datasets in the workspace and I need to compare one column in each dataset against each other and get only those rows in the output where the value will be the same. I tried to look for some more filters, but I didn't find anything functional.
Thank you, very much
  • Jun 16, 2021 1:04 PM UTC
You can e.g. use the FeatureMerger on the common attribute and only use the features exiting the Merged and/or UsedSupplier output port.
Forum|alt.badge.img+54
  • Jun 16, 2021 2:12 PM UTC
The FeatureJoiner is another option.
fmesafe.podpora
I try it, thank you very much.
