Fill color DXF-Cells
Hi everyone!
I have a DXF-Templatefile with cells (Microstation cells). Since these cells are overlapping with lines and both are white, I woul like to add a gray fill color to the cells, so they are still visible.
I hope someone can help me?
Thank you very much!
pratap
Forum|alt.badge.img+12
  • June 17, 2015
If you want overlapping cell color should be changed then separate the cells which overlap and not-overlap with the help of spatial relator and attribute "_related_candidates" and change the color which overlap and add to writer
  • June 17, 2015
Hi Pratap, Thank you for your input. I already have the features separated. The problem is to fill the cell with a color. If I use DWG Styler transformer, only the outline is colored after written to DXF, even though I set the DWG Styler to color the area as well.
pratap
  • June 17, 2015
Then you have to use format attribute and alter it as required before writer... Please look in the inspector which format attribute is required to change it... It might be either fme_color or igds_cell_element_color.
