File extensions understood by FME Readers
  • Jan 22, 2020 2:14 PM UTC
  • 67 views
spatialcase
Folks,
I need to scour some file shares with a python script to identify any data files.
I would like to exclude 'non data' files and it occurs to me that one way of doing this would be to compare file extensions with a list of format-specific file extensions that are used by FME Readers...
The Knowledge Base does list file formats (https://www.safe.com/fme/formats-matrix/ ) but doesn't specify the associated file extensions.
Does anyone know if there is a matrix that lists the file extensions associated with each FME Reader?
Many Thanks, Graham
Best answer by redgeographics
Check the formats.db file in your FME installation directory (it's a csv), that has a list of all supported formats as well as their extensions.
Forum|alt.badge.img+63
spatialcase
  • Jan 22, 2020 3:49 PM UTC
Fabulous - Many Thanks!
spatialcase
  • Jan 24, 2020 4:59 PM UTC
Following redgeographics' tip, I have pushed a python script up to GitHub - this reads the FME formats.db file and produces a CSV file breaking out each of the file formats that can be read by FME in a digestible format.
https://github.com/spatialcase/Python-Misc
