File Copy - Iterate - Move to Subfolder not Root File Path
  • Jun 24, 2019 11:45 PM UTC
  • 129 views
nz
Hi Team,
I have a folder structure with thousands of DWG files in multiple sub folders.
Excuse the naming convention, its purely indicative.
Currently as below, all the DWG files reside inside the DWG folder.
I am trying to create the following,
In the current workspace I have a Directory and File and Pathnames reader to FileCopy Writer
The reader reads the "TESTIN" Folder with "Recurse into subfolders" as the checked option, running a path filter of "*.dwg"
I have an Attribute Manager translator to assign 'Path_windows' and "Path_filename" to the writer.
Currently the writer output location is set to the same Root level "TESTIN" folder using the "SourceDataset_PATH" parameter (which is default), with the fanout expression of "_PLANS\\DWG"
This result obviously searches all the folders for the .dwg extension and then copies them all to the TESTIN\\_PLANS\\DWG folder that is created by the fan out expression.
My question is, How do I get it to produce the output directories in each subfolder, rather than the root TESTIN folder?
I am relatively new to FME, so the more detail the answer the better!.
Thanks in advance.
nz
Forum|alt.badge.img+63
A SystemCaller with the copy command would do the trick too, although you'd probably have to jiggle some wildcards for a bit, or use a Directory and Files Pathname reader and then iterate through all the .dwg files and issue a separate copy command for each.
nz
  • Jun 25, 2019 3:13 AM UTC
Thanks for the reply @redgeographics, I have been scouring multiple threads for answers as well as your suggestion. I have tried a solution to a similar problem set from 2017, Where @takashi suggested using a filesplitter and listindexer. This simple process has allowed for the fan out expression to be enabled to the desired location. In that case the users solution was for a level up using _dirpath, but Takashi's solution was my desired answer for a level below!
https://knowledge.safe.com/questions/42582/how-to-select-a-folder-within-the-folder-path-to-u.html
