FGDB with 0 feature inside
  • Jun 13, 2023 10:23 AM UTC
  • 87 views
Greetings,
I have a weird issue where the ESRI FGDB writer runs with NO error messages.
It writes out to an ESRI Shapefile, but the FGDB has 0 records???
This is the FME output
Total Features Read                                                      68587
                           Features Written Summary
Hazards_3857_20230613_Geom                           11021
Hazards_3857_20230613_NoGeom                         11021
Hazards_3857_Geom                                    11021
Total Features Written                                                   33063
The output in the FGDB?
Any assistance is appreciated, it is really frustrating.
itsmatt
Forum|alt.badge.img+48
  • Jun 13, 2023 10:29 AM UTC
Any warnings in the logfile? In certain cases FME can skip features when writing to certain formats because of bad attribute values or an unsupported geometry. Usually these are logged though so you would have a very large chunk of warnings.
It seems the issue was it was trying to write a field that I had converted to Txt, as Double/Numeric rather than Txt??
itsmatt
  • Jun 13, 2023 11:35 AM UTC
Right - yes if the column is defined already in the FileGeodatabase then it wont be able to update the table unless you set the Feature Type/Table to Drop and Recreate rather than just 'Truncate' or ' Use Existing'
There is a big debate that has raged about whether this kind of thing should be an error or a warning...
