FeatureWriter doesn't overwrite every file in ZIP folder
  • Apr 1, 2026 11:03 AM UTC
  • 113 views
antja
Forum|alt.badge.img+11
Hi everyone,
I’m currently facing an issue with CSV FeatureWriter transformer writing in a ZIP folder. We recently migrated from FME Workbench 2020 to 2025 and the behaviour of the writer changed in between.
  1. 2020: when writing a CSV in a ZIP folder, the entire ZIP folder would be overwritten. Meaning that if it contained several files, only the newly written CSV would remain.
  2. 2025: when writing a CSV in a ZIP folder, only the specified CSV file in the folder is overwritten. Meaning that all the other files are still existing. I get the same result with FME2024.1.3.
Main question here: Which FME version has the correct behaviour ? Case 1 or case 2?
If it’s case 2, then it means that I will have to update all the workspaces in my infrastructure that are writing files in a ZIP folder, leading to a lot of extra work → I probably need to clean up the ZIP folder upstream through a SystemCaller or PythonCaller. Have you other options in mind?
Please find enclosed a folder with relevant resources:
  • sample CSV
  • FME workspaces (2020 and 2025)
  • ZIP folder ‘TEST_CSV.zip’ with 2 files in it, when using FME2020 one file gets overwritten and the other deleted
hkingsbury
Forum|alt.badge.img+73
  • Apr 2, 2026 12:30 AM UTC
“Main question here: Which FME version has the correct behaviour ? Case 1 or case 2?”
Great question! And I can see both sides….. It really depends on whether you see a .zip as a folder/directory, or a file…..
I’d be more on the side of 2025s approach, as FME just looks at a .zip as a directory and opens it on the fly….
But I can fully understand why you’d expect the 2020 approach as a .zip is a file* (as far as your operating system is concered)
*or a container, but at that point, is it just semantics? as you could call any file a container for various content types
Forum|alt.badge.img+63
I agree with ​@hkingsbury in saying that the FME 2025 behaviour feels like it’s the correct one.
