FeatureReader not accepting point data
  • Jul 24, 2025 4:28 PM UTC
  • 92 views
bubblebeb
I have found that the feature reader will not accept point data as the initiator.
I have since found that in Version 15 a change was made: -
  • Spatial operations will reject initiator features with point geometries to match native reader behaviour.
Does anyone know why this was changed and if there is a way to force it to accept points without having to create a very small buffer to it and then recreate the point after the feature reader.
Best answer by desiree_at_safe
Hi ​@bubblebeb
What you’re describing is a known issue. While I can't say for sure what underlying problem the 'match native reader' change was meant to solve, I’m happy to note that it has since been fixed in FME 2025.0.3 (Build 25241) 🙂
I see you’ve already identified the current workaround, creating a small buffer before feeding the points into the initiator port, but for a full fix please use FME 2025.0.3+
[Internal Note: FMEENGINE-86850]
desiree_at_safe
Forum|alt.badge.img+25
Hi ​@bubblebeb
